long/short shaft conversion
ourgray
Hi would appreciate some advice<br />I have a long shaft 8A Yamaha outboard (Appx 1975-80) which is great except I could do with<br />it being a short shaft!<br />is it possible to convert this easily to a short shaft?<br />From the casing it looks possible, simply to take the mid section out.<br />But,I don't want to damage any seals by finding out. <br />If it's not possible I'll sell it and buy a short shaft<br />hope this makes sense.<br /><br />thanks in advance<br /><br />graham<br /><br />would appreciate mail direct thanks<br />graham@hope2911.fsnet.co.uk
oldboat1
Re: long/short shaft conversion
You can do it, but will need a shorter driveshaft and shorter water tubes and shift rod. I'm not familiar with your motor, and the long shaft may involve/include extensions for these parts which can be removed, but it's more likely you will need parts for the short shaft model. If you are not up to the conversion, you may want to sell your model in favor of a short shaft one (as you suggest in your post).
