Long shaft to short shaft??
ted655
Suzuki 150 2cycle EFI I have a chance to buy a good powerhead with bad longshaft. Included in the deal is a second "parts" motor, same motor but bad powerhead, good shortshaft. Is this as simple as switching lower units? Or....?? :rolleyes: Thanks Ted
JB
Re: Long shaft to short shaft??
I really doubt that Suzi ever made a short (15") shaft 150hp engine for recreational use. <br /><br />You need clarification on shaft length. . . in terms of the transom height it fits.
ted655
This is the ad. "2002 SUZUKI 150 EFI ( 2) MOTORS This ad was posted from the Louisiana Classifieds<br /><br /> THIS MOTOR IS A LONG SHAFT WITH NO LOWER UNIT, THE SECOND MOTOR IS A SHORT SHAFT MOTOR WITH A BAD POWER HEAD AND A GOOD LOWER UNIT, I HAD BOUGHT IT FOR PARTS.$3,500 FOR BOTH PHONE 337-849-6797 OR 337-224-0789 "<br />.<br />Too late to call, will call tomorrow as you suggest. Thanks.<br /><br /> :D
rodbolt
what JB says, I dont think they ever made the EFI 150 in a 15"(short) shaft. but they may have.<br />they did make it in 20" and 25"
deejaycee_2000
They do fit, but it does sounds dodgy about the short 15" shaft, but I might be wrong ..... the ad said nothing about the first motor without the lower unit, being in good condition, just watchout for that .... good luck
Ray Neudecker
Need to check, but many people today refer to the 20 inch as a short shaft.
ted655
Thanks guys. To a Cajun, if one is less than the other then it's short. I take your point that a "true" short shaft is 15" and that seems too short for that much transom weight at that HP, so I bet it is 20".<br />Boy, don't we all need luck when buying a want-ads motor! Thanks.
