I'll try to post some pics later...
I have 750 hours on this original engine. It's mostly used in salt, but with a full closed cooling sytem. I do a lot of long 20-50nm offshore runs so I'm up on plane for the duration. I'm never WOT for very long, but heavy with gear and hopefully fish on the return. Much of the time is trolling or drifting at idle. Runs fantastic, no hiccups, issues, nada...just been a great engine to say the least. I run a 160* tstat. The only overheating issues ever was a cracked raw water housing that allowed air into the cooling system. That was when I bought the boat on '03, but nothing since.
The last few years, the exh mani's were getting flaky at the exhaust openings, underneath. I know these powerplants tend to run warm and I did have saltwater dripping on them at one point in time. With 750 hours, it was time for new ones. My ring gear lost a tooth last year so now was as good as time as any to pull the motor for the first time. Before I started, the compression check was 152-153psi on all 8. When I bought the boat in '03 with 93 hours, they were all 155psi. Woohoo...so I figured!!! I ordered up some GLM's mani/riser kits and y-pipe o-ring. Yes, I've heard the GLM horror stories...but I have several friends who have used them with great success. All For the price I paid, it still an awesome deal even if they need resurfacing out of the box. Figured now was the time to change out some other components to have spares for the future too.
Yesterday, I pull the engine. I knew the water shutters were toasted so no surprise there. I was shocked to see the condition of the metal on the exh mani bolt heads and cyl exh port openings. Rust and flaking was horrible. The metal was splitting and flaking just like underneath the mani's. They looked like an overheated brake disc. The exposed cylinder head bolts looked like the exh mani bolts. Both port and startboard sides are the same. After 3 hours of drilling and grinding, I got one mani off. The head mounting surface is horrible but intact even with flaking metal. At a minimum, I'll have to pull the heads and TRY to have them resurfaced, but I don't think they can take that much off. Even if they can be trued, I suspect the condition of the heads at the exhaust may put me on borrowed time.
I need some advice:
1) Should I even bother with the current heads or just replace?
2) What can I do to reduce the temp/heat out the exhaust? Lighter loads? Different prop?
3) I can buy a 330hp-425hp MAG reman long block for $2600-$3100, 7 year/500 hour warranty from a reputable local company.
4) I'm leary of changing heads because of past experiences. Seems like head jobs are shorter term fixes. New heads tend to hurt existing rings sooner than later.
ANY INSIGHTS ON THIS IS GRETALY APPRECIATED, GOOD OR BAD! Just want to make an informed decision. This site has ALWAYS directly and correctly guided me through many a repair, but now it's on my own boat!
Kevin
I need some advice:
Kevin
