Re: Long or Short Shaft?
Thanks so much for the replies, appreciate the insight. My situation is I bought a boat with a bad motor. It must have overheated pretty hard because the water pump was burned up, pistons are scored (115 & 100 psi comp), water jacket gaskets were leaking, and the "honey" is dripping out of the stator harness sleeving. It looks like fixing this motor will cost much more than it is worth, so I'm on the lookout for a replacement or a donor power head with good parts. If I go the replacement route I want to make sure I get something that fits.
Thanks again,
Joe in St Louis
PS: Leads appreciated
