Re: Long Block
As others have mentioned, it all depends. Most all long blocks that I have purchased came with everything but a water pump and intake/exhaust manifolds - oil pan already installed etc. Given the different oil pan configurations now days however, some won't install an oil pan thus leave the pump off as well - due to many times the pan will dictate pump and or pickup design etc..
Seriously, best advice is for you to buy a good, high volume oil pump and pickup/screen for your application. That way you know the "heart" of your lubrication system is as good as the rest of your long block.
Good luck
