Re: Loctite
Willy, interesting to run into you again.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
When you mentioned that OMC products are rebranded loctite, would this be Quickloc for blue and Ultraloc for red? Also, does loctite have any anti-corrosive properties? <br /><br />I'm finally coming to the conclusion that OMC Gasket Sealing Compound has a bit of thread sealer, corrosion inhibitor, and thread locker all in the same package. When in doubt, use the Gasket Sealer? I can't think of a case where using gasket sealer on threads would do any harm. I'm paranoid about corrosion/seizing on those aluminum alloy engines and the factory manual doesn't always specifiy what to use.<br /><br />At my local dealer, a mechanic said he uses loctite or OMC Gasket Sealer for just about everything. He puts in the head bolts dry. I understand this is to get the correct tourqe out of them, but for saltwater use, those bolts will seize for sure!
