Re: locked up
I'm a mechanic and not into boat sales.If you are talking a 23 FT boat for $1200,it sounds good.Cosmeticallt how does the boat look?Good upholstery?Not cheap to have done.Fiberglass dull <br />I imagine.Cracks and chips?Won't look good until repaired,not cheap.<br />Motor locked up probably why it's been sitting two years.Sitting shouldn't have locked it up.<br />Figure $3000.00 for a good engine,and install it yourself,or pay someone.<br />Next you have to address the outdrive.Is it good?If not rebuilds are too expensive,so aftermarket drive is $1500 plus.<br />Above all this you have gimble bearings,ujoint bellows,shift cables and electrical parts to consider.<br />Not trying to scare you,but trying to indicate what you are getting into.<br />Find a boat that at least functions well in the water would be my advice.<br />DHP
