Locked up lightwin 3
kk158
Does anyone know where,um, or if I can get engine part for a lightwin 3 (pistons & rings) Thanks
JB
Re: Locked up lightwin 3
Ahoy, KK.<br /><br />Welcome to iboats. :) <br /><br />Yes, you can get parts, probably right here, but you need to give us the model number to ID the year so you can get the correct parts.<br /><br /> http://www.boatmotors.com/parts/ <br /><br />Good luck. :)
Paul Moir
I noticed piston rings available here the other day. Come to think of it, these might still be available from the dealer. It's worth a check anyway.<br />No sign of pistons though.<br /><br /><br />If it's just lightly locked, you may free it with penetrating oil applied through the spark plug holes and a go at the flywheel nut (unscrew). If you loosen it, tighten it back up to 42 ft/lbs.
