Sea Rider
- Sep 20, 2008
- 12,345
A friend of mine has this 2 strokes 15 HP-OB, last time out he couldn't pull the rope to start it. A tree shade pseudo mechanic told him it was caused by low use along excessive salt buid up on internal crankshaft 's upper and lower bearings and oil seals which is out of this world fantasy as this OB has never been submerged in salt water. Told him that it could be due to improper fuel/oil mixture. The issue is that he newer runs it past plane rpm and doesn't recall if adding sufficient 2 strokes oil on last tank refill.
If it were my OB would have removed starter assy, both plugs, apply an overdose of W40 on both cylinders while OB laid at fully horizontal position for product to penetrate rings well for some time and then rotate flywheel by hand bit by bit to both sides for rings to cede till fully operational.
Instead let pseudo mechanic take OB to his shop, the guy has dismantled the whole powerhead to clean the supposedly salt issues. Seems have assembled powerhead with old removed gaskets which is a must not do as are already deformed. Would not be surprised if the guy put silicone to sit crank case's gaskets back again...
Tomorrow will have a serous talk with this guy about what he's done to unlock the OB as my lawyer friend doesn't know anything about OB's, just that needs fuel and oil and voilá. Just in case will run it with fresh fuel and required 2 strokes oil amount and not use what's been already poured into fuel tank that could be counterproductive and lock OB back again.
Do you guys buy this mentioned scenario ?
Happy Boating
Happy Boating
