Hi, i have a mercury 2.2(single cylinder) serial number is A816133 with the number 312 below it.no water is coming out of the little pipe coming from the block, at first there was a trickle but now nothing, i can blow straight through so no blockage i take it that the impeller is just above the prop just tried to undo the stainless bolts carefully and YES both have snapped what is the best way to sort this out. the engine had been serviced and starts first time with loads of compression it would be a shame to throw away.<br />rayiow
