I have a livewell that had a livewell pump that wasn't working. At that time water would trickle into livewell and stop when it got to overflow. Water did not come into livewell from overflow.
I have installed a new rule livewell pump at transom and replaced the hose leading from livewell pump to livewell. When I went to the lake, the livewell pump worked great with timer, but water now enters my livewell through overflow. The overflow does not have a shut off lever, it remains open at all times. Water did not come in through overflow opening into livewell, before. Now it fills the livewell through overflow and I can't recycle water very well since it stays at overflow level. Can anyone help.
David
David
