Live bait tank
vacabill
Use to have a bait bag on transom, this time I want to build a round bait tank, on swim platform, have a round barrel 18 gal. will be removable. Will try to add attachment of my drawing, any other info. will be appreciated,don't know if you can see on attachment, but a removable pump 600gph on transom, overflow at top with screen. Will be used for anchovies. also a pic of the boat it will be on, 25' searay 1985
Hashi
Re: Live bait tank
Looks like you have it all figured out but you may have problem with weight distribution. Also, I would install the pump above the water line maybe on the livewell and run the fill tube down the transom below the waterline with a wider opening at the inlet end and screen attached to it. Why immerse the entire pump in the water.
Anchovies like current/oxygen to go through their gills so you may want to put the tank fill tube at horizontal position to keep the water going around your circular tank.
Just my two cents.
