Joshua Nichols
- Jun 29, 2009
- 1,431
So I drain the outdrive today. About 2 table spoons of water came out.
. I was expecting to have this problem, from what was told by the previous owner.. He thought it was leaking at the bearing carrier. Which I have yet to see.. I know I need to rig up someway to pressure test the sucker..
Anyhow I also wanted to take a look at the impeller.. I was impressed with the design.. So easy to inspect it.. Impeller looks new, but I find gear lube in there.. Not a lot but a noticeable amount..
So this i what I am thinking.. Is it leaking past the seals and/or the gasket on the impeller shaft? What yall think?
