little tiny hole alpha one driveshaft
affa
Hi<br />Im painting my outdrive, and when brushing it I saw a little hole on the opposite side of the vent screw on top of my drive shaft, it could look like it was something like that on the opposite side as well, but not that deep.<br />Does anyone know what it is for, and how it is suppose to be? Should I try to close it?<br />Regards <br />Affa
crazy charlie
Re: little tiny hole alpha one driveshaft
Be much more specific as to where your concern is.I cant picture where you are referring to.Charlie
affa
Sorry about that<br />It is 1-2 inches under the vent screw (where driveoil will come out when its filled), just above the mercruiser decal.<br />Regards<br />Affa
BRIAN03
The hole is a drain for the upper part of the shift shaft cavity. They usally fill with sand. If you are in a cold part of the country the drain should work. If water is trapped in there it will freeze and crack the top forward part of the case. If it get cold where you are dont cover it up.
affa
OK<br />Thankyou, I was able to blow air in the hole and then it opened up on thee other side as well,<br />Regards<br />Affa
