Fester
- Mar 25, 2008
- 63
I am having problems with my tilt and trim.....when I hook it up it just clicks one time up or down....I was told that I have to check for proper coltage...done and fine....then I was told that I need to bypass the solienoids and plug directly to the battery to see if the solenoid is defective.
The biggest questions I have is when I hear the clicking it is coming from a small black box next to a large plug mounted on the plate next to the powerhead (Mercury 115hp 2-stroke Inline 6)......The only thing I can find that is even remotely close to it is a voltage regulator....if it is a regulator, is it for the entire engine or just for the tilt/trim? and do I have to replace with factory original or can I replace with generic with appropriate specs?
