Links not opening/working
lonewolf41
Trying to access MPI fogging procedure on the VP DIY sticky page item 21 on http://forums.iboats.com/forum/engi...d-engines-outdrives/366271-vp?_=1508082118469 . When I click on the link a new page opens, but it is blank. I have tried 3 different browsers and a mobil device and all behave the same. I tried other links on the same page with the same results. It is like all attachments/file are broken or something. Never had trouble in the past.Is it something I am doing or is something broken?
GA_Boater
It works fine for me. The link is to a PDF file which is Saved to your device or displayed using the Open With option when clicked. I'm using Firefox with those options.
You need Adobe or a PDF viewer on your device to display PDF files.
lonewolf41
I figured it out. I was not logged in orignialy and then I had to clear my cache and then re-login before it would work.
Thanks.
