Re: Link'n' sync 76 15hp Seahorse
The sync is very easy to do tdp.<br /><br />Look at the cam under the flywheel and locate the hash mark on it. On your model, I believe it'll be a line on the cam.<br /><br />When the line is centered on the cam follower roller, the throttle plate should just start to open. <br /><br />On the starboard side of the carb is a pin through the throttle plate shaft. With the engine in gear (motor not running) watch the pin as you rotate the tiller handle hand grip. Just as the pin starts to move, check the position of the line on the cam in reference to the cam roller. The line should be centered on the roller. If not, losen the cam screws and adjust the cam in or out. Retest. The screws (small 5/16" head bolts) are under the cam. Also, you will have to remove the carb cover for the testing. <br /><br />That's all there is to it.
