Re: linkage/synchronization problem
Hi Destiny,<br />The first position foward, or the first position in reverse basically just controles the shifting, and has little or no effect on throttle. The problem that you're describing could be caused by a number of things. It could be as OB says,a sync problem with the carb. plates, or an idle timming problem, but if nothing has been changed I would put my money on dirty carbs.,or not enough idle speed, which again points to one or more of the low speed jets being plugged. Also don't forget to check for spark. I've seen a 70 h.p. that sounded real good idling in neutral with only one cylinder firing, but as soon as it was put in gear it would die.<br />Just my thoughts, but I hope it helps.
