Re: Link and Sync Procedure
I start by setting the cam on the lower carb so the butterflies close all the way. Then I set the adjustment on the top carb so the cam follower is in the middle of the top mark of the throttle cam...here is where problems start. When when I move control all the way forward, The roll pins on carbs come nowhere near close to hitting the stops. If I aadust that nylon, "L" screw setup it throws out everything else. If I adjust throttle cable, I low idle screw is way too far from stop. <br /><br />Bottom line: I need another inch of travel on the butter flies to get the roll pins straight up and down. I was thinking if I could get real good detailed pics of your rig, I could get mine staticly set and adjust from there as needed. I just got this motor, so I have never seen it set up correctly. <br /><br />Anybody got any suggestions?
