pontoon chief
- Aug 9, 2004
- 116
I am working on a 1987 90 hp yamaha 2 stroke.
It was missing on the botton 2 cylinders.When I choked both of the cylinders, they would fire.
I rebuilt all three carbs and started the motor.It sounds better,but it does not sound right.It kicks every so often and will stall.
I checked the timing,and at a 1200 rpm idle it fires at 10 degrees after TDC.When I advance the throttle the timing does advance as it should,but I am unsure of what the correct advance should be.
All three cylinders fire,as I pulled the plugs off while the motor was running and the motor misfired when I did so.
I am not sure what the timing and link and sync procedure is,and I do not know what the proper timing setting is,and infact I am not sure timing is the problem.
Can anyone help me out here.
