Link and sink
heycods
I have a water trough I can put under my boat and fill with water 1.5 ft deep holds about 80 gals. If I put this under my motor, can i go through the final sections of the link and sink procedure while running my motor in the tub?
OBJ
Re: Link and sink
You will need to get the water up over the mating line between the lower unit and mid section heycods. This is to make sure the water pump is submerged and will pump. Idealy, getting the water up on the midsection where it would be if the boat was setting in the water would be the thing to do. Sometimes hard to do so just get the water level up on the midsection as far as possible. A large garbage can can sometimes work or a 55 gal drum.
Dhadley
Re: Link and sink
I used to use a big tub at the marina. But we always ran the flushette too. That insures water to the pump and the water in the tub muffles the noise.
DHPMARINE
Re: Link and sink
I'm not sure what your linc n sync involves,but if you need to run much above an idle (in gear) you'll be amazed how fast 80 gallons of water will disappear.<br /><br />DHP (talking about your 88 HP)
reeldutch
Re: Link and sink
running wot with a prop in a barrel is asking for<br />problems. you need a testwheel and a good test tank.<br />Danger is the word in my mind.<br /><br />but for getting the backpressure to set the idle i think it will be safe.
heycods
Re: Link and sink
Originally posted by reeldutch:<br /> running wot with a prop in a barrel is asking for<br />problems. you need a testwheel and a good test tank.<br />Danger is the word in my mind.<br /><br />but for getting the backpressure to set the idle i think it will be safe.
Thats what Im after, its on my 50hp jonny
rolmops
Re: Link and sink
You can probably link just fine,but it will be hard to sink your boat in 80 gallons of water
