I have an older mercruiser (233 HP ford, alpha drive, circa 1977)<br />The power trim won't raise the outdrive. It will lower the drive but nothing happens when you try to raise it.<br />This installation has a linear trim sender (took me about 2 hours of searching just to find out what it is called and what it looks like.) does anyone have any knowledge of this type of sender and is there a trim limit switch somewhere? There are no "pucks" on the gimbal housing like the ones an my alpha 1 drive (another boat) and if there is a limit switch, I assume it must be somewhere inside the boat. Is there a chance the limit switch is part of the linear trim sender? Also, does anyone know of where I can locate a wiring diagram? I have a Clymer shop manual and the only reference it makes to the linear trim sender is how to test it.<br />TIA<br />Jim
