lights
llfish
What configuration/ color should my lights be at anchor. Orwill they be the same as my running lights. On my boat I can toggle between at anchor or navigating. I am getting ready to rewire the lights because they do not work. The project would be much easier if the at anchor and running lights were the same.<br /><br />Thanks<br />Larry
Specks n Reds
Re: lights
You didn't say how long your boat is.<br /><br />At anchor you should be showing the anchor light only no navigation lights.(running lights off)
llfish
Re: lights
The boat is 17'. What color is the anchor lights and where are they located at.<br /><br />Thanks for your input
mikecjn
Re: lights
When in the 'Navigation' position, you should have your bow lights (red & green) and also your stern light or anchor lights on. <br /><br />When in the 'Anchor' position, all you will have is your white anchor light on.<br /><br />More info on light requirements can be found at: www.auxetrain.org/lights2.html<br /><br />Hope this helps.
llfish
Re: lights
Yes you have been a big help!!!!<br /><br />I thank you.<br /><br />Larry Fish
