Re: lights,where do I put em?
first off,I would not like to blind other boaters,nor to be blinded by others,I am concerned with the 'mis-interpitation' of a forward facing light in conjuntion with the red/green light,I was gong to go with a average candelpower -not a daylighter or upper end wattage,I was going to install a semi-ajustable for the vertical so I can ajust how far ahead the lights will pan.<br />I am planning on mounted light,not hand held,less B.S. to dink around with.<br />do I have the light mounted on the deck,like the red/green light or do I bring up the light from the deck a few feet-say from the upper part of windsheild or canopy?<br /><br />thanks for the info for glare from the deck and how it can affect visual accuity at night.<br />as for the dash lights,they all are red lighs,all the swiches are under 'dashboard'<br /><br />do I /can I mount the horn under dashboard area ?<br />again I have the swich panel under dash,that is where the horn swich is going to go allso.<br /><br />I am working on installing throttle and sterring,right now its tiller drive,so when I gotta flip a swich,I gotta move forward to swich panel.<br /><br />cram time for spring,tail end of restoring a 1959 uniflite 14'
