Light u-joint noise hard turn starboard
workkyle
I have a
2004 Chapparel 204 SSi 5.0 mercruiser. At slow speed I can hear the ujoints in out drive when hard starboard turn. I barely him that at 32mph. Port turns no noise. Can I grease them or do I have to change them to correct?Or drive it as is until worse?
Scott06
I have a
My 2003 vintage drive had sealed aka non greaseable u joints
Could also be gimbal bearing as well which may be greaseable from outside of gimbal housing
If it’s not terrible use it through the season and change at winterization pull the drive inspect for water in bellows check alignment while in there
nola mike
You can always roll the dice...a couple of seasons ago had some knocking, pulled the drive and had a slipped u joint clip, joint was banging on the drive shaft nut. Could have been bad news if I continued to drive it.
Searay205
You already wasted more time then it would have taken to pull the outdrive and replace the u-joint. On all my boats, friends boats over 30 years never had a bad u-joint, I suspect you found a symptom and the problem is a water leak contaminating you u-joint grease
dubs283
This means statistically you will not find a bad u joint. Keep up with the annual inspection, service and repair
OP: remove boat from water. Pull the drive and inspect issue. U joints do fail from water intrusion and on their own
