Lifting Eye for 90 HP Mercury Motor
111torrance111
Trying to buy a lifting eye that attaches to the flywheel, both stores I called have them as tools but not for resale.<br /><br />Q1. Where can I buy this lifting eye?<br /><br />Q2. Is there another SAFE way to lift this motor, I have obtained a 2 ton motor hoist which will go high enough to do the job. Just want to make sure I don't damaged the motor.<br /><br />Jerry
tashasdaddy
Re: Lifting Eye for 90 HP Mercury Motor
111. i made a sling for my 1350 with the cowling on i ran it thur the front and rear 'handles' i use a large quick link as a ring for the hook to go into.
111torrance111
E-Bay had them available. Thanks rickrster.<br /><br />Tashasdaddy,<br />My Mercury only had rear handles, but thanks for the help.<br /><br />Jerry
Texasmark
If you can get a nut (for the top of the crankshaft) weld a steel loop on top of it. My '02 90 hp lifts by this type of "hootus" and I made a rig with a chain. Can't say it works (it should) as I was going to lift my engine to install a new steering cable and found out that I didn't have to.....after I built it.<br /><br />Mark
