Re: Lifted F250 with bed camper and boat
I just purchased a boat and trailer which were manufactured in the US. I guess one braking axle is the norm whilst here in Canada brakes on each axle are mandatory. I would deffinately get brakes put on your trailer, as for me, mine are surge brakes and I need to overhaul/rebuild the whole system. I will also be installing additional brakes on the second axle and just tee off the existing line.
Yes. Many trailers have brakes on one axle and the other axle (the front axle) remains as an idler axle. Before running out and installing brakes on the idler axle, suggestion doing some simple "upgrade benefit" math first. Thus, determining if brakes are mandatory or a "nice to have" - for your unique Tow Vehicle + trailer combo.
For simply math:
- Obtain the "empty" Cargo Capacity of your Tow Vehicle. For example, my V6 Tow Vehicle is 2,000 lbs. Many V8 Tow Vehicles are 3,000 lbs (or more). For now, let's assume its 3,000 lbs. re: 3,000 lbs can fit in the vehicle's insides and trunk - before being over loaded.
- With average loaded Tow Vehicle, determine remaining Cargo Capacity. For example, 1 x passenger @ 250 lbs, 100 lbs of cargo and a 50 lbs dog. Thus 400 lbs of cargo. Simply take 3,000 lbs - 250+100+50 = 2,600 lbs. 2,600 lbs of remaining Vehicle Cargo Capacity.
- What is your attached trailer's "average" loaded Scale weight? For example, let's say its 3,800 lbs. Thus, why 2 x 3,500 lbs axles are used under your loaded boat trailer. Or, perhaps 2 x 2,200 lbs axles under your boat trailer instead?
- For now, take 3,800 lbs (loaded boat trailer) and subtract 2,600 lbs (remaining Tow Vehicle Cargo capacity) = 1,200 lbs. If your trailer had NO brakes, your Tow Vehicle's factory brake system would be over taxed (over stressed) by 1,200 lbs. Thus, great idea to install Trailer Brakes. Without trailer brakes, your Tow Vehicle would risk warped brake rotors and other mechanical damaged - from being over stressed.
- Since 1,200 lbs is the "over stress lbs amount", your attached trailer only needs brakes on 1 of its 3,500 lbs axles. And if installing brakes only on 1 x axle, it get's installed on the rear axle. Installing brakes on its 2nd axle would be an over kill. And, a waste of money.
From a pure math calculations, your Tow Vehicle + Trailer combo only needs brakes on 1 of its axles (its rear axle).
Hope this tip helps…
