LIPowersports
- May 23, 2023
- 16
2011 LF225XCA left trim piston binds immediately engaging in trim after tilt. The trim piston and seals were changed due to a trim fluid leak. Last season after install, the trim moved smoothly then after a few weeks it started sticking to the point you’d have to toss your weight on the back of the outboard while trimming to free it. Something aint right. All Yamaha parts were used. I noticed the trim piston/seal design changed. Original design used outter circlips above the trim seal (pictures below) to no circlips. Fluid is clean, has plenty and I added grease on the piston ends to restrict any friction. What am I missing? Now the outboard trims better after spraying some CRC on the trim piston while exercising, but it still makes a binding sound. The right trim piston doesn’t bind however the left one does. Both were changed together.
