Lets talk about electric consumption...
Mark42
A 15 watt florescent bulb will burn for about 66.66 hours on one killowatt of electricity. <br /><br />If one kilowatt hour costs 20 cents, then 66.66 hours of light will cost only 20 cents. <br /><br />Right or wrong?
crab bait
Re: Lets talk about electric consumption...
MAN,, run outta projects to do ,or what..??.. :)
chuckz
Right for an incandescent bulb, wrong for a flourescent bulb. The efficiency of the flourescent bulb is less than 100%. However, flourescent bulbs give you more light output than an equivalent incandescent bulb becuase a lot of energy is wasted as heat in the incandescent bulb.
JB
Yes, Mark. Your math is accurate.
ZmOz
Originally posted by L.I. Chuck:<br /> Right for an incandescent bulb, wrong for a flourescent bulb.
Depends whether it's a compact fluorescent or a standard tube. If you have a 25 watt shop light, for example, the tube will use 25 watts but the entire fixture will use more than that. On a compact fluorescent, however, they are rated by what the ballast uses...so a 15 watt CF bulb only uses 15 watts total.
jlshields
20 cents per kwh! Man that's expensive. Here in central Indiana it runs less than 8 cents, 7.91 to be exact and we get darn reliable service too.
Mark42
ZmOz, are the compact flourescent bulbs the ones that screw in to replace standard incandescent bulbs?<br /><br />JlShields, I think we pay between 9 and 12 cents a kwh, I used 20 for round numbers.<br /><br />Thanks JB!<br /><br />Bottom line is leaving a 15 watt compact flourescent bulb on as a night light is not really wasteful because it is rather cheap to operate.
ZmOz
Originally posted by Mark42:<br /> ZmOz, are the compact flourescent bulbs the ones that screw in to replace standard incandescent bulbs?
Yep.<br /><br />
Originally posted by Mark42:<br />Bottom line is leaving a 15 watt compact flourescent bulb on as a night light is not really wasteful because it is rather cheap to operate.
Yep again. Even at 10c/KW, a 15 watt CF bulb only cost $0.0015 per hour. Even a plain old 60 watt bulb only cost $0.006 per hour. Compact fluorescents are hardly worth the initial investment unless you have a light that's on 24/7.
Bob_VT
Flourescent bulbs use a ballast (at least the long ones do).... does that suck up any power in addition to the bulb when in use??
chuckz
Yes, the ballast is a transformer, it's not 100% efficient.<br /><br />If it generates heat, it's dissipating power.
ndemge
All right, Lightbulb conversations in the Summer time ! I thought I had to wait for winter for this :) :) <br /><br /><br />..... I keep a 14 watt floresent in the garage on 24/7, no switch on the wall, so if I walk in at night, I have to stumble over things to hit the pull string, so just put that light in and leave it on.
ZmOz
Originally posted by NoelMG:<br /> ..... I keep a 14 watt floresent in the garage on 24/7, no switch on the wall, so if I walk in at night, I have to stumble over things to hit the pull string, so just put that light in and leave it on.
I do the exact same thing. :D
Paul Moir
The heating season lasts 7 or 8 months here. So you get to use your energy again as heat for the house. Since oil is about half the cost of electric heat, for those 7 or 8 months you get 5c of your 10c back as heat, which averages out to about 3c off each KW spent over the year.<br />Somebody asked me once why people with electric heat bother shut off their lights at night in the winter. :D
