Re: Lehr 15
I got to play with one at the Miami boat show. It looks very well made. It's actually easier to pull over than the 9.9 as the 15 is equipped with a compression release. The only draw back I found is that it will want to be fed liquid propane when running at high speed. The regular tanks that supply gas to stoves and the smaller engines just can't supply enough propane vapor to keep it running at high speed.
I plan to use a 32 pound fiberglass forklift tank in my little boat. I'll mount it horizontally under the seat.
Couple of questions
1 Did you pick up the 15 yet?
2 When using the forklift/golf cart tank where do you get one?
3 Do you get those tanks filled the same way at a regular refill station or do you have to go to a commercial refill station?
I currently get my tanks refilled at Uhaul.
4 Is there some type of gauge so you know how much propane is left in those tanks.
Sorry for the questions but my experience is limited to 10 an 20 pound tanks in my boat ( 2 1/2 & 5 gal )
