island5278
- Apr 12, 2011
- 7
My left turn signal and left brake light are not working on my trailer. Everything else - both running lights, right brake, right signal, works. I've eliminated everything on the trailer. If I use a light tester to test the plug on the truck side (Jeep Cherokee 2001), everything seems fine and I have a signal on the yellow wire when I'm supposed to. If I then plug it into the trailer and retest with the light tester, I get a very, very dim response from the turn signal with the light tester. If I swap wires - connect yellow truck to green trailer and green truck to yellow trailer, the problem moves with the swap. So that shows my trailer wiring and lights and I assume ground must all be good.
My blinkers are not running fast when I connect to the trailer. I've seen that mentioned as a fairly common symptom.
I'm thinking it's either the vehicle flasher or the converter. Does the flasher have anything at all to do with the brake light? If not, then I'm guessing it's the converter.
Just to be sure, I also eliminated the connector by bypassing it.
Any ideas? I've spent a lot of time to get this far.
