levittownnick
- Jul 2, 2003
- 789
Last year I purchased several long strings of these LED lights thinking that LED's should have a longer life than incandescent bulbs.Bad Thinking.
I have a Greenlee Voltage Detector that I purchased several years ago to help isolate open filaments in series strings of decorative lights but that doesn't work with the LED strings. I'm only guessing but it don't work with the LED's because they only draws current on 1/2 cycle leaving full voltage on the other 1/2 cycle so that the Voltage Detector thinks all the lamps are open.
The question is: Without removing each of the LED's 1 at a time and checking the socket, is there a reasonable troubleshooting method?
A side question, I see a small module in each string that looks like it has 12 resistors. Are these just to limit current (or are these not resistors)?
Thanks,
Nick
Thanks,
Nick
