Leaking Velvet drive 10-17-008 1:91:1 Ratio
offshore 25
Transmission fluid is leaking from around coupler nut on the transmission. The rear seal is dry around the outside of the coupler. Is there a seal or gasket behind the nut?
Grub54891
Re: Leaking Velvet drive 10-17-008 1:91:1 Ratio
Don't think there is a seal there. When assembling it should have had a sealer applied to the shaft/flange. I alway's do put some there,same with the vibration damper in the motor,sealer keep's oil from migrating down the shaft/keyway and leaking.
Grub
Google velvet drive transmission,I just did,found a few service manuals in pdf form. Did not read them,just downloaded for future reference.
offshore 25
Good news. The nut holding the coupler one the trans shaft came loose. tightened and good to go...
Grub54891
Good,was wondering if ya got it fixed!
Grub
