Jgran
- Mar 29, 2016
- 8
I recently purchased a 1992 Colbalt 222 with a 7.4L 454 and had it inspected by a local Mercruiser dealer. Everything checked out fine but it was noted that there was some seepage at the connections between the exhaust manifolds and the risers. The previous owner told me that he had installed new manifolds and risers the previous year. I figured that if there was external seepage, there could be internal seepage as well and it needed to be checked out. Long story short, last weekend I began to loosen the riser bolts on the starboard side before I drained the water from the manifold/riser assembly. As soon as I saw the first trickle of water on the outside, I quickly realized my oversight and drained them within 2-3 minutes while a little water continued to trickle out from the gasket area. The risers and manifolds look fine and I have cleaned the mating surface to a near perfect with a scraper, razor blade and then 220 grit sandpaper on a flat wood block to remove the stubborn spots. I read in the forums that I definitely need to use the OEM gaskets and install them dry. The new gaskets will arrive tomorrow and I am hoping to get the boat ready for the water this weekend. While reading through threads, I am getting concerned that when I loosened the riser bolts and the water leaked out that there obviously was the potential that water also leaked into the exhaust manifold and into the engine. Based on the condition of the gasket it appeared that the inner chamber was sealed better than the outter but there was definitely the potential for a little water to enter the engine. I figured that rather than cratering the engine before I ever get off the launch, I should swallow my pride and see what my next step should be. Options I have considered range from turn the key and pray, remove spark plugs and crank the engine so water has a place to go, etc. Any input would be appreciated. Any tips on reinstalling the gaskets? Thanks!
