Re: Leaking hydrolic fluid from power trim HELP
$42.00 for the part at the local marina, but also realized I needed an American flag so, that meant mounting hardware, clips, teak pole, etc...over $100 later I leave the marina with what I actually came for. It turns out there was definitely a leak in the resevoir and it is a real bear to get at the thing. One thing I noticed is that the old resevoir looks to have melted on the inside and this is what caused the hole/ leak. Is this something I should be concerned about reccuring? The bolts are in the back and getting them out was OK, the oil that had leaked was everywhere and that did not make things easier. But trying to line up the whole apparatus and get the bolts back in was killer...After two hours upside down I finally got at least one bolt in and will start fresh on getting the last tonight...
