Re: leaking coolinat out of my lower unit
just took off the heat exchange. Water runs freely out of the coolant and out of the seawater side. Any ideas on how to test for leaks in it or should i just take it to a radiator shop and have them look at it
You can use the automotive type radiator pressure tester to pressurize the FW side of the system (you would need to hook up the hoses again to the cooler, but I would leave the sw hoses off). When you pressurize it, the pressure should stay steady. Based on what you said, I would guess you will see coolant come out one of the seawater ports on the cooler.
Autozone will "loan" you the pressure tester. They charge you a deposit for the tester, when you are done they refund you fully. It's one of the tools on their "loan a tool" program.
