JOEYBELL321
- Sep 10, 2002
- 3
I recently replaced the gaskets on my 165 4cyl mercruiser thinking my coolant was leaking there.<br />However after completion I found it leaking from a factory hole in the timing chain circulating pump housing.I believe this tells me there is a leak in maybe the circulating pump and the hole prevents atifreeze from entering the oil.before I disassemble again Id like to be sure.thanx
