Leak
mobgod
I'm going crazy not sure if it's normal I have a 200TXL77C I put stable seafoam and a oct booster in my tank for my first fill up but i'm seening oil and gas ofcoarse on my transom from what i can tell looks like the carbs are spitting it out and it's just dripping from there. I guess my question would be is this a normal thing or do i have to much fuel going to the carbs i'm lost or should i just burn this tank of gas than check again?
colding
Re: Leak
I'm curious to this answer as well. My 2005 90 HP is also leaking oil & gas at a very slow rate. I've also noticed that is doesn't do it when the motor is trimmed all the way up for transport, only when it's trimmed down. AND, it doesn't seem to do it all the time. It doesn't seem to effect the way it runs.
boobie
Re: Leak
Have you checked the fuel lines coming from the vro to the carbs for any leaks ?? Is the line from the air box going to the intake manifold on ??
