Re: leader help
Your bottom fishing may be a little differant then around my way. We don't have oil rigs but we do have rocky structure and sunken vessels and we fish in 200' of water <br />From main line to leader like Snapperbait says is a good swivel. All my leaders are fluorocarbon just a matter of preferance, [always caught fish on mono] Fluro is tougher then mono and will hold up better to abrasion. Leaders are generally 4-5' long. <br />for deep sea fishing I use a 2-3 hook set up spaced a couple of feet apart with a bank sinker on the end. The sinker will be anywhere from an 8oz-20oz depending on current.<br />When jig fishing I use the same as above but the only differance is I put a 10oz- 24oz jig depending on the current.<br />One of best & quick knots to tie is a Palomar knot to the hook,[strong]<br />I don't use crimps until I get into using 180-300lb test lines mainly used for giant blue fin tuna fishing.<br />I make up my own wire leaders from 12"-24" long. attach the swivel first and then the hook, easier to do that way.And I generally use 70-80lb single strand wire, which is Malin stainless wire [brown]Also I buy my hooks a hundred at a time
