Re: lb's of thrust
DR - I think the 70lbs vs 1hp comes from trolling motor comparisons. The trolling motors have very high thrust props that you don't see on outboards so they can move heavy craft with their weeny motors.<br /><br />Anyway, real life speed propellers produce a lot less thrust. It's a bit of a wild guess, but I would think about 1000lbs hull resistance at full speed would be in the ballpark.<br /><br />Another way to look at it, do you really think you could park 3 midsized cars on your transom? Or howabout this one - that the engine could completely lift two boats out of the water, straight up?<br /><br />To answer edjr's question though - why not ask CMC? I see it's rated for 130, they might just say it's fine for the DT140. The way I've seen it, what really matters is the weight bouncing around on the transom rather than the thrust. But ask the people who designed it.
