angterry
- Mar 20, 2010
- 5
Hello to all, I am looking for a few answers that I am hoping someone could help me with. I have a late 80's model Mercury 200 on a 24' deck boat. Motor has always ran fine, but has always shaken and smoked at idle and no wake speed. I mix 50:1 and use Pennzoil Marine TC-W3 Premium oil. I run sea foam in every other tank. I full up (half tank, 30 gallons) every week. It seems like the smoke is coming from the the small square on the rear of the motor just above the water line. I thought that this was a through the water exhaust, or am I incorrect? There is no smoke in the cowling. Boat was on salt water for a good chunk on it's life, but has been in fresh water for the past 5 years and gets used about 4-5 times a week.
Second, could having the wrong size prop cause the problem? The reason I ask, is at WOT with a 19 pitch aluminum prop I am pulling 7200 rpms and only running around 34 mps. I believe that I should be around 6500 rpm, so I need to go to a 21 or 23 pitch prop, but just havent found the right SS prop yet (I hate to buy the wrong size, so I am trying to find one to borrow for a day).
I thanks you all in advance for any help that you can provide me. Thanks and have a great day
