Late 50's Evinrude / Johnson
trebot
Looking to power my 1957 16' Thompson with late 50's Johnson / Evinrude. Concern is parts, wiring harness and service manual availability. Also what is good compression for 30-35 hp motors? HELP
Honorary Supreme Mariner
Most consumable parts are readily available and likely at the dealer.--------Other parts are also available but require patience.-------Certainly cheaper motors to own that the new high tech motors if you can do the work yourself.
gdc0581
I'm in the process of restoring a 1957 Johnson golden javelin. About a year ago I walked into Seaway marine with a list of about 20 non-maintenance parts. I don't remember all of them, but they included piston rings, the shift rod for an extended shaft, and the rubber strap that catches the front door. They had everything in stock. I had to wait a couple of days for the shift rod because it was in an outlying warehouse. Seaway is incredible. After installing the new rings, the compression was 120.
