Larson 176 SEI Outboard Slipping
troutC130
My Larson 176 SEi is slipping after I engage the prop past about 1500 RPMs. After that the RPMs go through the roof and the prop stops spinning. Any ideas on what the problem might be?
Please either reply here or email me @ Kamkorder15@hotmail.com
troutC130
Re: Larson 176 SEI Outboard Slipping
I forgot to add that it has a Volvo Penta engine, its a '98 boat, and is an inboard/outboard
steelespike
I would suspect a spun hub on the prop.A prop shop can test and replace the hub if necessary.You'll get better info in the I/O section Or perhaps props.Try props seeing it appears to be a prop issue.
