katfish2123
- Dec 12, 2008
- 26
What year, model, size is this motor? Dad says a Lark IV
Model - 40372D
Ser - E03531
The boat has been setting at my uncles house for 5 years or so. He said it ran when he put it up.
First off, I read a thread from 2005 that had a very similar situation to the one I have.
http://forums.iboats.com/showthread.php?t=103361&highlight=lark+iv+model
The pictures in this thread look just like my engine. It has plenty of problems, but as for right now I am trying to get it to get fuel. Has new plugs mentioned in the thread (J4C) new fuel tank and fuel, plenty of compression. I haven't tried sucking and blowing on the pressure side of the fuel pump line hose though.
I did, however, take the carb off and clean it up. I don't understand where the jet would be on this carb as I have not worked on a carb before. In that thread they said they had all of the same situation as me and it ended up being trash in the jet. Is that the hole that goes down to the bottom of the bowl?
Also, the starter looks to have been on an off many times. There are only 2 bolts holding the starter bracket on and I believe there is supposed to be at least 5.
It has no generator and I believe it was just taken off on purpose as the yellow and blue (or yellow and green) wires for it are taped off in the engine compartment.
The motor has selectric shift as I can tell from the posts on here. I rewired the whole fuse panel/block and voltage regulator before I noticed that it didn't have a generator. BTW, It has a very nice schematic drawing inside the box if anyone needs a picture of it.
The shift/throttle cable is locked up and by reading the other post that may have something to do with it.
When I do get this thing to run, I know I want to put a water pump/impeller in it or at least have one around.
whew..... I know it is a lot. Just wanted to get as much info out on the first post as possible. I'm sure I missed a lot and will have to fill in the blanks, but any help on these issues, parts and lack of knowledge would be greatly appreciated as this boat has a lot of meaning to me since I learned how to fish and ski from it and now it's mine.
Thank you in advance.
Katfish
Model - 40372D
Ser - E03531
Katfish
