Re: Lanyard kill switch
EvinFla<br />If your switch is a double pole single through (6 contacts) move the wire from one end to the other keeping the wire on the same set of contacts. Or if a single pole single through switch (3 contacts) same thing. This will "reverse" the switch. if it has only 2 contacts, turn the switch over, that is if its one of those after market add in's that uses a togle switch.<br />Richard
