Technologic80
Thread starter- Joined
- Aug 1, 2011
- 65
When I first bought my boat, the genset ran fine. But would turn itself off after about 10 minutes. No biggie, we would just time it to be done with whatever (coffee maker, microwave) by then. It wasnt that much of an inconvenience but I definitely noted its odd behavior.
I changed the impeller, checked the sea strainer assuming it was getting too warm. No difference.
It finally shut down 3 weeks ago and hasnt restarted since. It did this once before and I was able to get it running again by tapping the fuel pump and carb bowl with the plastic end of a screwdriver, then putting carb cleaner into the carb to get it to start. Thats not working any more. Ive got plenty of fuel going IN to the fuel pump. I dont even know where the fuel line goes IN to the carb to check.
Its a 1997 Kohler 4cz23 gasoline 4kw genset with 5, yes 5 hours. New plugs, new air filter, just changed the oil (kohler oil filter/10w40 oil as recommended), new Kohler genuine impeller. When it runs (I have oil & temp gauges) both are in the perfect operating range - the temp never leaves 160 degrees and the oil psi stays right around 50-60psi.
SOMEBODY PLEASE help me before I set fire to my hair and shoot this generator to the moon!!! :facepalm:
