gimmieaclue
- Mar 6, 2010
- 40
Just put a new riser, a new to me exhaust manifold and all new gaskets (including head gasket) on my 470. She started right up so I retorqued the head bolts after it warmed up and let'er run in my driveway for another 20 min or so and all was well. All the work was done because of a corroded riser and exhaust manifold.
This morning I get the boat down to the dock and its acting hard to start and when it does there was a pretty good cloud of smoke and some serious knocking so I shut it down.:facepalm: Got it home and found a bent pushrod, not real bad but bent. Would a slight bend cause a lot of racket? What would be a likely cause? I've read a lot about stuck valves but it was running fine last night. Yes I had to pull the rockers last night to torque the head again but it ran fine afterwards. Maybe a lifter?
Any help would be appreciated,
thanks
I should add that the knocking went away with a little throttle and that it backfired a little when I turned it off also the plugs looked/smelled fouled.
thanks
