Kosmofreeze
- Aug 23, 2023
- 37
I've got a 5.7GXi-A. The knock sensor screws into a brass fitting (a tee) that extends from the block drain on the starboard side. The sensor screws into the tee such that it is parallel with the block. The 90-degree part of the tee is just a threaded plug that allows the block to be drained. The problem is sand and grit get caught in the 90-degree bend and plug up the drain. The only way to clear the sludge buildup when winterizing is remove the knock sensor and the fitting and blow it out ... then reinstall the fitting and knock sensor. If it was a straight-shot into the block I'm sure the "coat hanger trick" would clear the sludge but with the 90-degree bend I'm unable to clear the clog with out removing the sensor and fitting.
So I put it all back together and now I wonder if my knock sensor is still working. How do I know?
