knob assembly
yellow bird
I have a 5.5 johnson, seahoarse outboard. vintage is somewhere 1970 to 1974. I need the mixture knob assemble that controls the mixture from lean to rich. should be around 4 parts, give or take. I need these parts so that I can go fishing, can not control the trolling speed at all without them. any assistance out there?
Hooty
Re: knob assembly
Try these folks.<br /><br /> TCO <br /><br />c/6<br /><br />Hooty
Joe Reeves
Re: knob assembly
Ed.... Those adjustments, once adjusted and locked (so to speak) so that they won't viberate loose, should never need moving unless the carburetor becomes fouled.<br /><br />I don't have the parts you need, but depending on which type carburetor you might have on that engine, the proper adjustment procedure follows.<br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /> <br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.<br />----------------------------------------------- <br />(Carburetor Adjustments - Two Adjustable N/Vs) <br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns. <br /><br />Setting the high and low needle valves properly: <br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Bear
Re: knob assembly
Big Ed, take a look at this picture. <br />It is a '62 3 hp carb. The low speed needle look the same as on my '66 6 hp. (It doesn't have the adjustable high speed needle.)<br /><br />Can you see if you are missing more parts than just the knob?<br /><br />My knob is broken so I drilled a tiny hole through the tiny splines at the end. I put a tiny nail in the hole. Looks like a T-handle. Works perfect for me. <br /><br />It's up to you. Drill the hole and go fishing or order and wait for parts. No fishing. :D
