Kiwi Phils gardening corner. Making a Compost Bin
Kiwi Phil
<br /><br /> This is the MOST IMPORTANT part of a Veg Garden<br />If you have a “fall” (autumn), then put all the leaf matter in the compost, put all your lawn clippings in: if you prune trees, then cut up the thinner branches with secuteurs in small bits: in go ALL your weeds: all scraps from the kitchen. Every bit of “green matter” has to go in. DON’T WASTE it. This ‘burn it or dump it” mentality is a waste of a valuable resource.<br />Makes for cleaning up your property quick and easy too.<br />My compost holds 10 cubic yards, divided in 2 parts. I fill one, which takes months, then cover it with an old carpet until it becomes fantastic compost. You will know it when you see it, and start on the 2nd one. Remember I am a commercial operation tho.<br />To get it out, I unscrew the roof-batten screws holding the side on with the power drill and dig it out.<br />Hayden collect the horse manure from across the road for me. I also add nitram as I have a big sack I want rid of since 9/11. <br />It was made with 6 sheets of old iron, 6 posts (I drilled up ind and inserted steel pipe, which is driven in to ground.$60.<br /><br /><br /> <br />Info from other site. <br />The secret to vigorous plant growth is using the finest of all organic fertilisers, compost. Almost anything can go in to compost from tea leaves to newspaper. It is virtually impossible to fill a compost heap, you can keep topping it up with organic garden and kitchen wastes and watering it down without it getting full. <br /><br />There are different kinds of compost heaps. The smaller lidded bins are problematic in that they do not reach high temperatures, thus the waste takes a long time to degrade and weed seeds and pests are not killed. However, they are useful for small gardens, produce good compost and are full of worms. When the matter in them has degraded, they can be lifted up and moved, leaving a heap of compost for use in the garden.<br /><br />If you are in a hurry to obtain compost, use a rotating bin. Organic matter is placed in the bin, the lid is closed and the bin rotated about two or three times a day. The bin has bars inside that mix up the compost and speed decomposition. Once finished, the bin is tipped up and the compost collected in a barrow.<br /><br />The best way of making compost is to create a couple of wooden frames, one will contain fresh compost and the other old compost that can be used. The compost heap needs to get hot in order to kill weed seeds and pests. The base of the frame should be open to the soil. It should not be concrete because the worms must be able to escape the heat generated by the activity of bacteria that are breaking down the waste.<br /><br />Begin by making a layer of organic matter, about a third of the depth of the frame. Next add a layer of manure such as sheep droppings, to weigh down the organic matter. This will encourage the bacteria to grow. A second layer of chicken manure is also good. It is essential to saturate the heap with water.<br /><br />Start layering again with more organic matter containing straw and kitchen and garden wastes, you can even add cotton clothes. Build up successive layers of organic matter topped with manure and watered down each time until you have reached the top. Deep saturation is important, so water until it runs out the bottom. Water the heap regularly thereafter. The heap will become extremely hot. This means that it is working.<br /><br />You can tell when the compost is ready to use as there will be no recognisable lumps of organic matter and it will have a rich soil texture. Use the compost in the plant hole of seedlings and for conditioning the soil prior to planting. Avoid using it as a mulch, rather mulch over the top of it with straw or dig it into the soil.<br /><br />Making one, however small, will be best thing you ever did.<br /><br />Cheers<br />Phillip
Kenneth Brown
Re: Kiwi Phils gardening corner. Making a Compost Bin
Thanks Phil, I'm ready for lesson two.
CalicoKid
Sounds about like my garden, pretty sandy here so every bit of organic matter I can get ahold of goes into the compost and in turn on the garden. I haul a few tons of horse manure per year also. Makes great soil after composting!<br /><br />One word of caution: Do not add meat scraps or dog or cat manure (all carnivores) to the compost it cannot be sterilized enough to be safe. And besides, yuck! :p
salty87
no offense calico, but KP what's your take on dog waste? i feed my dogs raw meat and bones only, would like to find something to do with the waste. which, coming from that diet is quite different from the usual 'load'. everything is fully digested and turns white/crumbles in maybe 2 days.<br /><br />thx
Kiwi Phil
Calico is correct. Do not use it. Put it out in the rubbish, and if it is too hot to leave in your bin for days, then freeze it until rubbish collection.<br />You may recall, a lot of tape worms etc (eg hydatids)have their life cycle with the dogs intestine/bowl.<br />It is unsafe...period.<br />Cheers<br />Phillip
18rabbit
Absolutely NO dog or cat waste in your compost. I remember reading something about critters that eat meat don’t produce waste suitable for compost, but critters that eat veggies do, i.e. cows, horses, etc.<br /><br />I just made a compost bin out of a 55 gal drum. Heat is a necessary component in getting the vegetation to break down during composting. A drum compost bin is painted flat black, gets hot enough inside to kill seeds, and if rotated daily will make a batch of compost in 1/8th the time it takes to make pile compost.<br /><br />Does it work?!? I dunno. In all of my brilliance (or not) I built the thing just before the start of winter … no more hot sunny days. Haven't tried it yet, but it looks cool.
heycods
Thanks again phill
Kiwi Phil
18R - excellant idea, easpecially if you can get it "to roll". ie something like an "A" either end, centre pole, so it is horrizontal. Add manure (horse/sheep etc,) or nitrogen in form of nitrogen fertilizer as a "starter". These drums are very efficient. Keep adding water.<br />My bin was about 2'overfull 4 days back and now about 6" underful. Checked it today and it is rotting away beautifully.<br />Cheers<br />Phillip
